将下面代码里面的路径改为自己的,保存为lsp直接运行就行了
(defun c:LISMEN ()(setq la (getstring "\n输入图层名"))(setq ss (ssget "X" (list (cons 0 "TEXT")(cons 8 la))))(setq fi (open "C:\\test.txt" "w"))(setq si 0)(repeat (sslength ss) (setq ssn (ssname ss si)) (setq ent (entget ssn)) (setq ct (cdr (assoc 1 ent))) (write-line ct fi) (setq si (1+ si)))(close fi))
