linuxf二次开发中 ->XData 问题
在生成的示例程序里,我是在void initApp()里新增了一个命令 acedRegCmds->addCommand(ACRX_T("ASDK_SAMPLES_HELLOARX"),
ACRX_T("ASDK_test"), ACRX_T("test"), ACRX_CMD_MODAL,
TestXData);
该命令的实现代码为
AcDbObjectId appendEnt(AcDbEntity* _pEnt)
    AcDbDatabase* pAcDb=acdbHostApplicationServices()->workingDatabase();
    AcDbBlockTable* pBlkTbl;
    pAcDb->getBlockTable(pBlkTbl, AcDb::kForRead);
    AcDbBlockTableRecord* pBlkTblRec;
    pBlkTbl->getAt(ACDB_MODEL_SPACE, pBlkTblRec, AcDb::kForWrite);
    pBlkTbl->close();
    AcDbObjectId id;
    Acad::ErrorStatus es = pBlkTblRec->appendAcDbEntity(id, _pEnt);
    if (es != Acad::eOk)
        pBlkTblRec->close();
        delete _pEnt;
        _pEnt = NULL;
        return AcDbObjectId::kNull;
    _pEnt->close();
    actrTransactionManager->queueForGraphicsFlush();//刷新显示
    actrTransactionManager->flushGraphics();
    acedUpdateDisplay();
    return id;
AcString _AC_STR_(QString qstr)
    return AcString((const char*)qstr.toUtf8(), AcString::Utf8);
AcString _AC_STR_(char* str)
    return AcString((const char*)str, AcString::Utf8);
QString _T_(ACHAR* str)
    return QString::fromStdWString(str);
char *_SZ_(QString _qstr)
    char *str;
    QByteArray ba = _qstr.toLocal8Bit() ;//不可以 _qstr.toLocal8Bit().data() ,如果这样,可能会出错
    str = ba.data();
    char *ret = new char[strlen(str) +1];
    strcpy(ret,str);
    return ret;
void TestXData()
    Acad::ErrorStatus es;
    AcGePoint3d pt1(0, 0, 0), pt2(100, 500, 0);
    AcDbLine* pLine = new AcDbLine(pt1, pt2);
    AcDbObjectId id = appendEnt(pLine);
    es = acdbOpenObject(pLine, id, AcDb::kForWrite);
        acutPrintf(ACRX_T("\nError to acdbOpenObject"));
        return;
    QString strRegApp = "appreg",
            strData1 = "Dat1",
            strData2 = "Dat2";
    acdbRegApp(_AC_STR_(strRegApp));
    struct resbuf* rb = acutBuildList(AcDb::kDxfRegAppName, _SZ_(strRegApp),
        AcDb::kDxfXdAsciiString, _SZ_(strData1),
        AcDb::kDxfXdAsciiString, _SZ_(strData2),
        RTNONE);
    pLine->setXData(rb);
    acutRelRb(rb);
    pLine->close();
    AcDbBlockTable *pBlkTbl_read;
    acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlkTbl_read, AcDb::kForRead);
    AcDbBlockTableRecord *pBlkTblRec_read;
    pBlkTbl_read->getAt(ACDB_MODEL_SPACE, pBlkTblRec_read, AcDb::kForRead);
    if(pBlkTbl_read)pBlkTbl_read->close();
    AcDbBlockTableRecordIterator *pltr;
    pBlkTblRec_read->newIterator(pltr);
    AcDbEntity *pEnt_read;
    for(pltr->start();!pltr->done();pltr->step())
        pltr->getEntity(pEnt_read, AcDb::kForRead);
        if (pEnt_read->isKindOf(AcDbLine::desc()))// 符合条件的 多义线 作为判断的依据
                AcDbLine *pLine_read = AcDbLine::cast(pEnt_read);//whether it's a line
                if(pLine_read != NULL)
                        QString  strData1_read, strData2_read;
                        struct resbuf *pRb_read = pEnt_read->xData(_AC_STR_(strRegApp));//获取实体的扩展数据
                        if (pRb_read != NULL)
                            struct resbuf *pTemp_read = pRb_read; //使用临时的结果缓冲区指针进行遍历,pRb不修改便于释放
                            if(pTemp_read)pTemp_read = pTemp_read->rbnext;
                            if(pTemp_read)strData1_read = _T_(pTemp_read->resval.rstring);
                            if(pTemp_read)strData2_read = _T_(pTemp_read->resval.rstring);
                            QMessageBox::information(NULL,"info","acdbline::cast ok\r\ndata1=" + strData1_read +"\r\ndata2="+strData2_read);
                        else
                            QMessageBox::information(NULL,"info","acdbline::cast ok, but resbuf read return null");
                        acutRelRb(pRb_read);
                else
                    QMessageBox::information(NULL,"info","acdbline::cast error");
                if(pLine_read)pLine_read->close();
        if(pEnt_read)pEnt_read->close();
    delete pltr;
    if(pBlkTblRec_read)pBlkTblRec_read->close();
    QMessageBox::information(NULL,"info","test over...");
当在cad里test命令时,总是得到 QMessageBox::information(NULL,"info","acdbline::cast ok, but resbuf read return null");不知道是什么原因导致读取不到里面的数据,麻烦赐教,谢谢
浩辰软件的糕糕
您好,请私信一下我您的联系方式。我来协调研发老师协助您确认问题。
